Thread: clutch slip
Old 11-29-2005, 02:36 PM   #11
rnoswal
rnoswal's Avatar
Just a couple more suggestions. Replace the rear main oil seal while you are there and definately replace the input shaft bearing. Replace the seal on the front and rear on the gear box too. Make sure the spring wires that hold the throw out bearing stay on during the installation. Check to see if the clutch slave cylinder has any wetness around the rubber cover.
Clean everything. Inside the bell housing and outside the transmission. Check to see if you need to replace the plastic cup on the end of the shifter. If there is none, there should be.
Let us know.
Russ
