14 psi
I shimed my waste gate and run a straight through exaust I think you will be fine you will only hit max boost running at high speeds, 12 psi is fuel cut, so i would just work of that, play with it if you hit fuel cut, back off a little, and you really cant break the turbo doing what your talking about, the ct26 is more than capable of pushing 14 to 15 psi stock
