Originally Posted by mrnickleye
Go here to fix fan low speed.
http://www.supras.com/06/techcenter/...231c19a16cb495
I did this and it lasted for a year. So I went back in and replaced (soldered in place) the low speed wire coil with some small diameter 'stainless steel safety wire' from the local motor cycle shop. (they use it on race/dirt bikes) They will probably give you the 2-3" you need.
Done. I replaced the broken coil with some fuse wire of about the same gauge, wrapped it around a pen, 10 coils like the original. Works like a charm. Allthough the surfaces were really filthy and took a bit of rubbing with emery paper to get the solder to take to it. Thanks again for the help.
