i took it off the motor causr i bout the car with a broken rod and its hard spinning it with my hand. i think the remanings of the bearings got through nthe oil lines and scrued it up. if thats the case i debading on either fetting a t66 or an other upgraded ct 26 what do you guys think whats the best for street and strip. thanks guys hope to here from u shortly.
Originally Posted by sakara
is the turbine hard to spin? or does it just feel a little tight? if u don't have to crank on it to make it spin then it should be fine...
