no start
It sure sounds like the factory anti theft deterant system. my 86.5 does the same annoying thing a few times a year. I have found the solution!
1. exit the car.
2. lock the doors using the inside lock, not the key.
3. close the door; however pull up on the outside door handle while you are closing it.
4. look thru the window to see if the blinky light on the dash starts blinking.
if it does, then simply unlock the door using your key and start your car.
if it does not, try all steps again, or try on the passenger door.
(remember, its takes a bit of time for the blinky light to start blinking.)
