first thing i did
i replaced the air filter then the downpipe and always run top fuel in your car for better perfomance in the start if u can get a cheap mod chip i recommend that 2 for some minor stuff( oh u can shimm your wastegate 2 i myself did what others said to do but they recommend 4 or 5 washers i would recommend 2 to start to see if u like it) what u do is pull your ic pipe over your inlet tube then take your inlet out and u will see your turbo that has a diaphram type sensor connected to it take out the 2 bolts holding it on and put 2 washers inbetween the turbo and the sensor on each bolt so the sensor is farther away from turbo now what u are doing is telling the wastegate to open later which creates more boost which creates more power in the end give it a try and see what i mean oh and 2 wahers in each bolt won t hurt the engine aslong as u are smart about what u are doing when punching it try that and let me know
