Highly recommend getting the Pivot pop-up headlight adjuster from Ebay or something. It allows you to adjust the headlights to close at any height via a rheostat. By using this you can have your sleepy eye set up and when you need your headlights turned on they will close fully and open up fully then return to sleepy mode after you turn them off. You're looking around 70 bucks for this thingy, but it has full instructions and it's really easy to install.
