Might help
By changing one thing you will have to chang other things to compensate , like yeng and yang, good and bad, theres 2 sides so to speek, : eg; if you put bigger exhaust on you will need better inlet hardware, like bigger and better filter+throttelbody and pipping, turbo, injectors, aftermarket ECU to realy make it better, bear in mind bigger intake pips = more lagg not much but a little so length is best kept short, from turbo to inlet-valves,
Gigler
