Peak power is probably in the 5600-6000 range. If you floor it and shift around this rpm you should stay in the power band. I'm pretty sure the turbo makes 232 hp at 5600 rpm. Very similar engines... Go out and drive, then you'll know for sure, on a closed course hehehehe.
Nate
