Old 12-14-2005, 11:09 PM   #25
snowball
snowball is on a distinguished road
alanflies vbmenu_register("postmenu_3709686", true);
SupraForums Member
Trader Rating: (0)
i used a shop vac with the long plastic tube extension. about 1.5 inces diameter. fits right thru the hole in the third cover and can suck all the stuff out of the cylinder bore and the valley at the same time. as for how the fuel got there... im not sure check everything for leaks, make sure the injector clips are on the right injectors. maybe you are flooding out on 5 and 6 because they are switched....in any case. and im serious here. make sure you take your time and find the problem with the fuel and definately clean all the fuel from the piston bore and the plug valley before you get cranking. it prolly wont crank with all that fuel in there anyway due to hydro lock. make sure the plug connectors are fully snapped onto the spark plugs. spark + fuel in the valley will surely burn your car to the ground.
snowball is offline   Reply With Quote
