Thanks for the input fellas, I will check the water pump and test the exhaust, Im pretty sure it's nothing with the engine because the engine has about 3000 miles on it and was built by jasper, also I had the coolant system pressure checked so I know there is no leaks but I will check the water pump and exhaust since those are the only things I haven't checked yet, again, thanks for the input
