Old 12-19-2005, 05:30 AM   #12
joel w
joel w's Avatar
there are some posts on sm that are step by step on how to rebuild them, seems pretty strait forward if its rebuildable.. but i would send mine out so it can be properly set up and balanced.
best way to tell if its bad is describing the smoke when you run it.. idle and deceleration.. or oil in the ic like you described..
im sure someone else tell ya about the rebuild..
