It sounds like the dealer parts guy should pull his head out, but plug your ears, cause it will be a very loud pop. Or he's so new, he can barely wipe.
The proportioning valve is located down on the frame area up front. He should easily be able to locate the "T" you need at the back of the car. It will be very cheap. He will probably need to order it, (1-3 days).
Also try Carquest if you have one. Or an independent parts house. When I worked at Carquest, we stocked all the sizes.
