I perosonally have never seen a supercharged Supra. If you supercharge you will still need to upgrade your exhaust to get the most from that setup. A blow-off valve is still recommended with a supercharger and you might even have to upgrade the injectors as well. Adding a custom supercharger may seem simple but there is a lot involved in order to get the most from it as well as even getting it to run properly.
