Originally Posted by Evilfurby
I am thinking of getting 97 mkiv, how much power can the stock block hold? Can you get all that power on the stock TT's?
-Evilfurby
Well it depends on what your goals are. The stock block in my experience has been able to hold over 800whp fairly easily. And that will probably be too much for you. The stock turbos can produce an easy 650whp then you will either need to upgrade the turbos or go to one large turbo. Also you will need to enhance the fuel management after 500whp.
