Originally Posted by SKILMATIC
Yes your engine is a 7mg which is a inline 6 cylinder motor 2.8l. Labor cost for extraction and installation of motor you are talking some coin. I would guess something around 5grand.
Guys, lets lead this guy in the right direction. You have a 7m-ge, its a 3.0 liter Naturally Aspirated (non-turbo). Try to find a used JDM motor and have it installed for $1500+ or do it yourself. Make sure it is compression checked and have a leak down test done. Motor will be $350-$800, Install will be 1500+. Going turbo is not as simple as swaping the motor. You also need the correct harness, ecu, intercooler, piping etc... It can be done, but its more expensive.
