Old 12-29-2005, 02:21 AM   #10
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep, get a block test done to check for bad hg & do a compression check... at least you'll know if the motor is reasonably good
the o-ring is what seals the cps/dizzy in the head.. it will be old and plastic now so won't be doing a hell of a lot and will leak oil onto the exhaust manifold.. get an oem replacement and you'll be sweet
good luck with the car and post some pics
Pics of my build.
Do a diagnostic first!
