Originally Posted by suprra_girl
yep, get a block test done to check for bad hg & do a compression check... at least you'll know if the motor is reasonably good
the o-ring is what seals the cps/dizzy in the head.. it will be old and plastic now so won't be doing a hell of a lot and will leak oil onto the exhaust manifold.. get an oem replacement and you'll be sweet
good luck with the car and post some pics
pleas forgive my ignorance but what do you mean "hg"?
sorry ive never heard of a block test.
what all do they check for on the test?
