running like turd
i would say the easiest thing to do would be to pull a code from the computer, they have hand held tools that will make the check engine light flash to display the code. it will flash so many times, count them and that will be the first digit of your code, then there will be a pause, and then what you have to do is count the second set of flashes, and that will the second digit.
example: 3 flashes pause then 2 flashes = a code 32
if you don't want to go out and spend the money there is a way to jump the diagnostic connecter to make the check engine light flash the same way, a chilton manual would most likely have it , or someone on here should be able to descibe to you on how to do this.
