Originally Posted by Dboz
and again here
it has NOTHING to do with the fact its a V6.. its what kind of internals were used
leave out the style of motor arguement..
Again, you are misconstruing what I am saying. Any motor can put out any power as long as you have the money to do so. However, what I am saying is for stock block to stock block the cast iron inline blocks are the strongest and can put out more power stock than any v motor can due to the balancing issue. If you didnt touch any internals on a v6 and an inline 6 the inline 6 would be ableto produce more power much more efieciently and without fewer or any problems. If you do this to a v6 because its a v style motor the balancing on the stock bottom ends are usually only able to withstandup to 500whp. If you exceed that on a stock bottom end v6 you will have internal problems. On most cast iron inline 6's(usually refering to the 2jz's) those motors stock bottom ends can withstand up to 800whp fairly easily. Are you getting this now?
