Originally Posted by SKILMATIC
Really? So your saying THAT JUST BECAUSE SOMETHING hasnt happened yet you are automatically going to rule that out as never being possible? Gee I am so glad Einstein didnt have the same views you do when thinking about constructing the a-bomb. Furthermore, I am so glad every single inventor didnt have the same pessimistic views as you do. The supra has always been gravely underestimated in everything it does. And every single time when someone puts their mind to bringing out the best in the supra they have exceeded everyones expectations. You should have a little more respect for your supra as you claim you own. IMHO, someone that owns a supra would never have the pessimistic views such as yourself...
It's not pessimistic, it's realistic. The inventor of the a-bomb wasn't on the same type of budget as someone like Evilfurby looking at maxing out the stock block, stock twins horsepower of a used Supra that he's planning to buy. Something tells me the US Government had just a few more resources to throw at a-bomb development lol.
For any reasonable amount of $, you're not going to make 650rwhp using the stock twins alone. In fact, I'll allow you an unreasonable amound of $. You'll never do it even if you spend $25,000.00 on the problem (not counting the cost of the car itself). Is that a reasonable budget, iyo?
... what does mileage have to do with anything? I am assuming you are talking about mileage on the car not the engine. Because you said low mileage supra and not the motor. Well hate to break it to you mileage has nothing to do with power unless its on the motor. You could have a supra with 300,000original miles on it and just installed a rebuilt 2jz in it and it will and can be very powerful...
I'm talking about mileage on the turbos. They just don't boost as well if they've got a lot of mileage on them.
...Likewise...
I've already told you. I base my data on my own work on my own MK4, my work on other Mk4's, as well as the work of the dozens and dozens of other Mk4 owners that have worked on this problem and posted their results. Now, upon what do you base your BS 650rwhp on stock block & stock twins figure? Faulty mathematics? Lol.
...You mean to tell me that 650whp has the same stress tensions as having 400whp? Again, your brilliance amazes me. Now yes granted IMHO the motor can handle alot of power with little to no problems, but it is a given fact that the more power you put out the more stress the motor goes under...
No one is arguing with you there, but let's get back to the topic - is your assertion still that you can feasibly make 650rwhp with a stock 2jz-gte block and it's stock twin turbos?
...Not impossible. Improbable is the correct term. Nothing is impossible in this genre...
Prove it then! This isn't a matter of odds like rolling some dice at Las Vegas. This is a matter of how much air those two little 2jz-gte oem twins can pump. They simply can't pump enough air to produce that much horsepower. It's beyond the capability of those devices, therefore it's not improbable, it's literally impossible.
Now if we go beyond the conditions of your earlier posts and add a big single turbo or a big shot of NO2+fuel to make the horsepower, then of course it can be done. But again, on oem twins and oem block alone, there's just no way.
...You SURE YOU OWN A MK4?
Yes. I'm also sure that YOU shouldn't be posting on MK4 threads, because you're completely uninformed and unqualified to answer any questions about it.
