Originally Posted by SKILMATIC
Dude, no one ever said anything about cost aspects. I said it is possible to get that much. Even you should agree that it is possible. And if I had 25grand to spend on a motor and I had to use the stock twins. All I would do is max boost, racing fuel, bigger injectors, bigger fuel pump, standalone engine management, bore the engine out w/ stroker kit...
WHOA! HOLD ON THERE BUCKO! You said STOCK BLOCK. If it's bored out w/stroker kit, it's NOT STOCK anymore!!!
...exedy multi disc clutch, lightened flywheel with carbon pads, trd diff, better IC and piping, intercooler chiller kit, and 200shot of nitrous(wet kit)...
WRONG AGAIN. You wouldn't be making the power with the stock twins in that build. You'd be making it with the NOS. You said nothing about NOS in your earlier posts, and Evilfurby didn't ask about making power with NOS - he asked about making it with the stock twins.
...Theres your 650rwhp. Stock engine is 320 just the nitrous alone bumps it up to 520(and thats a maybe 1000dollar mod depending on where you get the kit from) I got 24 grand left. Any questions?...
No questions, but you broke the conditions you set up in post #7 of this thread. You made the power using a stroker kit & nos...not the stock block and stock twins.
...And your still wrong. As I have already maped it out for you...
Sure you made the power, but not with the stock block and the stock twins. LOL!
...I said the stock motor yes. Engine management, nitrous, and more boost I never said you couldnt use(show me where I said word for word that you couldnt use these things). With these things alone you can get that amount when done right. However, then you claimed that even if I could do anythign to the motor the stock twins wouldnt handle it. Which again is not true...
STOCK BLOCK = NO STROKER KIT. DUH.
...Bingo now someone is thinking. I never said once you couldnt use nitrous or any other means of management. Just stock block and stock twins. Anything else is a go. Now you are coming to reality. I see the dice is turning in my favor...
Let's forget stock twins. Why not take them off completely, and spray a 450 shot? LOL. Again, Evilfurby wasn't talking about making power with nos, and neither were you...till now.
...As you have already losed this debate about a mk4. You have already admitted that 650rwhp is attainable on the stock motor with stock twins with the help of nitrous which is a 1000dollar mod. Well what happened with the rest of the 24grand? I never said once you couldnt use nitrous. Thank you for debating sir...
You're welcome. I hope you enjoyed loosing when you broke the conditions of this debate.
...The funny thing is while I am not qualified to answer these questions you have just debacled yourself in your own debate. First you say "you need a unattainable amount of money to make 650rwhp on the stock block and stock twins" then you say "o but its attainable with nitrous which is a 1000dollar mod." Maybe you will take my advice and chose your battles much more wisely.
I'm glad that YOU finally admit you can't make 650rwhp with the stock twins alone. At least the others reading this thread know the truth NOW.
