Originally Posted by pwpanas
The best way to check for boost leaks is to pressurize your entire charge-air system with an air compressor (up to about 30 or 40psi - if it can handle 40psi cold, then 20psi or so hot should be no problem). With 40psi of air in your charge-air system, you should be able to hear any/all boost leaks loud and clear.
thanks very much , i can do this . I have an air compressor and im looking forward to tomorrow morning to do my tests. That's clever , never thought of it..Many thanks and i ll keep you informed.
