Sounds great. Did you get the ront cover machined with the block, or did you even do that? Maybe you will get lucky and find it's only the cam seals or the distributor seal. Sometimes, if the engine has been cleaned by a machine shop, the front and rear oil gallery plugs don't get tight or they put the wrong ones in.
What ever the case, these cars sound great don't they!!!
Russ
