Originally Posted by suprra_girl
i would think for speaker removal it's best to take the door panel off
BZZZZZzzzzzzz!!Wrong..The speakers for a MKII are in the lower dash..There are 2 acsess panels you have to remove on the driver side to get at the other bolts and the lower dash will come outward and then lower down..You will have perfect acsess to the speakers then..The passenger side is easier if you remove the glovebox lid and then the liner and you can go in from the side..Its more out of site but gives you more room to manuver..Going in from the bottom works also but its up to you..Here are some pics of the panels i was talking about.. http://i12.photobucket.com/albums/a2.../dashbolts.jpg http://i12.photobucket.com/albums/a2...dashbolts2.jpg
