Yep...bit of a drive, but well worth it in a good running supra. You could "see" America.
3/8" drive metric sockets is what I meant. You will probably need a universal swival adaptor too. You only need to take off the "Y" part of the intake. You can leave the throttle body on "it".
get a valve cover gasket set from the parts house. it should have all the needed gaskets.
If the #3 VC gasket (center one to seal spark plugs boots) is crappy looking, you'll have to order it from the toy dealer ($35).
Gotta go now, I'll check back later tonight.
