Old 01-05-2006, 08:10 AM   #2
suprafann
suprafann is on a distinguished road
agh those gains are outta wack.....ill tell you quick if u got time u would wanna.....put everythign as 0, put the deck at the volume you usually lsiten to....than tweek yoru amp until its distorts, put it back down a bit..than tune yoru deck
This is what ideally i think it should be, every system is different
BASS = 0
TREBLE = 0 +1 OR +2 OR +3
SUB LEVEL + 3
LPF = 80
HPF = 120-160-180
Amp gain, no more than 75%
LPF = 30-40%
HPF = 60-70%
and ya the subs get a low frew and the fronts get a high freq
your amps getting ht because everythings almost maxed out
suprafann is offline   Reply With Quote
