the alarm is very easy to disable. and ill have to agree sounds like either your alternator is bad, or you have a small short somewhere which can cause both things you described to happen. ive heard the back of the fuse block corrodes, and other things like that. I disabled my factory alarm in about 25 mins once i learned how. Just have to be very agile to reach it good. All you really have to d ois unpulg it thou, not take the computer out. and then you have to re attach the starter ground cable to the body, which will need a wire extension. goodluck with the car tho!
