1. Vacuum leak and/or bad sensor?
2. Yes, the combination switches suck. Not sure how to undo constant high beam.
3. Check your coolant level. If it begins to over heat, run your heater.
4. Not sure what you're asking with "teeth"?
5. The car seems OK to drive for 3-4 days, but sometimes you just can't tell.
