Originally Posted by 94T88Widebody
I have a highly (bolt on) modified 94 supra, stock internals. I recently broke the cam belt tensioner. when I replaced it I had thought there was trouble with timing. come to find out I was experiecing a melting spark plug. As the plug became worse the car ran worse until it did not run. I have since replace the plugs and can not get the car to star. I have spark on the number 2 cylinder but nothing on 1 3 5 have not tested 4 yet and 6 is a pain to get to... any ideas?
I am leaning towards the crank positoin sensor...
Drew
This may be a dumb question, but I just want to make sure. Did you gap the plugs or are the pre gaped? Also did you check your plug wires to make sure they are still good? Sometimes the plug wires will where out and one will work and the rest dont. I hope that helps or if it didnt at least we ruled out those possibilities.
