The master cylinder is right by the turbo and it gets hot. So I will need to make a heat shield to prevent the reservoir from melting. I cant bend the lines I have. I need like a flexible link that will connect the master cylinder and the line that cant reach.
The perfect thing would be a 5 inch flexible break line ( something that will not melt ) that can run right under ( touching ) the uppipe to connect to the master cylinder. That would be Perfect. ( =-----------> )
--===Give me 2jz-Gte or give me death!===--
