Originally Posted by SKILMATIC
I beleive he said earlier that he already checked compression and it checked out fine. This is what he said.
Sorry 100psi-120psi isn't "fine" for a 2jz-gte. As I
already mentioned to you in another thread, 20psi is beyond the maximum allowable difference between min & max cylinders.
Also ime these compression numbers are VERY VERY low, relatively speaking. Although readings do vary a bit between compression test gauges and depending on the exact procedure used for the compression test, (fwiw) I've never seen (only) 100psi in any 2jz-gte that is "fine". In other words, I agree with Suprra_girl & MrNickleye that the internals of this 2jz-gte need further inspection, and likely some (or a lot of) work+parts.
