Can you not determine the answer from my response? The simple answer is no. If you had an unlimited budget, then the answer is yes.
This is common practice with Honda engines. Although the engines have to be in the same family. For instance a B18A DOHC non-VTEC engines' head that came in LS and RS model Integra's is swapable with the B18C1 and B18C5 which are from the Integra GS-R and Type-R Integra's. A more potent and popular combination is using the B20 block from the CRV and putting a VTEC head on it.
