I just started to mess with my tails and to get them out there is three nuts under the tail light and above it, on the inside. The top ones are in little holes. If you happend to do this already let me know if you got the outer red lens off! I know on most head lights and tail lights you have to put them in an oven to heat them up so you can peal the lens away from the case. Id like to find a better way.
