There is a speed sensor on the back of the speedo. The computer sees that there is no input from the lack of a cable, so it is alerting you.
After you get the cable back in, it may stop blinking. If it keeps blinking, then you will need to disconnect the battery for a few minutes to clear the codes stored in the computer.
