Thread: TIMING!!!
Old 02-06-2005, 10:31 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the cams should be aligned with the marks on the backing plate behind the cam pulleys... you should see two lines and a dot on the cam pulley... align the dot with the small line
i would suggest getting someone to do your belt for you that has experience... if you get the belt out too far you can hit valves
i'm not sure if 5m's have diagnostics ports
Good luck with it
Pics of my build.
Do a diagnostic first!
