Need Help
I'm a new member and just got a 89 Toyota Supra Turbo. It is an automatic and the car really runs strong. However, the car wont start when it is hot and the starter won't even crank. I already replaced the starter and new battery and still having the same problem. A guy I knew told me that it might be the relay's??? Car starts right up when it is cold and you can drive it forever just don't turn off the engine cause it will not start not unless you use a jumper cable to jump start the car... Has anyone had this experience who can help me?
Thanks,
