Well...if you jump it with another battery, and it cranks right up, I doubt its the relay. This is a tough one. Check the battery connections at the posts. Clean them real good and put them back on. Check the ground at the engine block, too. And all the grounds.
Does the volt meter show about 13v when its running?
