Thread: Need Help
Old 01-19-2006, 04:15 PM   #9
scruffboy
scruffboy's Avatar
Default Re: Not starting
Several readers including myself have had a similar problem, and it turned out to be the factory installed alarm. If this accidently gets set, your car will not start, not even crank. To unset, insert key in door and turn twice to the right (open door position). Then get in and try to start it. If it doesn't work there, go to the passenger door, which is less likely to be worn out. Good luck. This may be your problem, many people have been bamboozled by this alarm.
Sincerly,
James in NJ
