Is your vehicle stock? How would you rate the condition of your engine? I'd give it a 2nd thought before bolting on that turbo setup. You'll definitely need some sort of tuning. At least upgrade the fuel system and AFM before you think about hooking up that turbo. You'll also need a custom downpipe and you'll need to upgrade your exhaust if you use it.
Function Over Form - Form Follows Function
88 MkIII Jurbo
