Keep in mind that they will only come on if the headlights are on..If you would rather drive with just them then rewire them into the parking lights in the housing that way they come on just before your headlights do..I have removed the reflector and the lenses with clear ones ,and also stepped up to a 100watt halogen bulbs..I Then bypassed and removed my headlights alltogether and ran my fogs off my headlight harness..If not you will fry the harness with such large bulbs..Check me out at http://www.cardomain.com/ride/858848
