check out
www.supras.nl
It's got very good guide on rebuilding a head with pictures.
don't use stock bolts since they are most probably too streched already and you will end up blowing your HG again
buy arp bolts or studs
also you will need to get your head machined if you want your gasket to last long.
for MHG you also need the block machined
