you guys arent talking about clinton, md are you?
2jz swap- pain in the ass splicing harnesses, need mounts and bellhousing made, pricey
1jz swap- need ecu, harness, bellhousing, mounts
7m- do i need to explain?
without a doubt, the 2jz would kick major ASS, if you could afford it. if you want a swap the 1jz would be a lil easier. personally though id stick with the 7m.
