ARP studs replace the head bolts. They come with an allen wrench I believe. Not sure how tight you set the stud though, or if they require any special lubricant when you install them. When you're ready to install the head they torque down with nuts, and they can be torqued even tighter than bolts.
Function Over Form - Form Follows Function
88 MkIII Jurbo
