standard maintainance and it should be ok...
tons of people say max boost on stock turbo is 15psi, but i disagree, ive killed 2 of them. and then did some research about them..i found out that it does not push any more air at 13 psi then it does at 18psi.. anything after 13 just creates heat and is counter productive...and it starts to overspin at 11 psi, so id stick to 10+ psi on the stock setup..
