Originally Posted by Johnny boy 82
Ok so 10 PSI Should I be looking at any other seals or is the head gasket the only thing I need other than that and a boost controller.
Thanks guys
John
depends on how much you want to spend. and how far you want to go with it... you will pretty much need a
head set , which contains all the other gaskets needed., like head, intake and exhaust and cam seals and valve guide seals, valve cover. ext. ext... its every gasket except the center spark plug wire holder gasket, thats dealer item only.. and when the heads off it can be checked for warping.. bad valves and what your plans may be in the future.. just depends how dependable do you want it? how well the previouse owner took care of it, how many miles on it and such. its alot easier to do stuff like timing belt and waterpump and other belts and tensioner and such while its apart.. and i hate doing things twice...
