Old 02-16-2005, 10:13 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
Originally posted by 300hpvision@Feb 15 2005, 01:36 PM
about how long have you installed the new stuff? if not too long it might be defective. also take it on the dyno run and see if it happens. ( if it starts that is.)
please stop telling ppl to dyno their cars and see if it happens
Supraman: it could be that you blew off intercooler piping, you installed a fcd you say? did you install it correctly, did the engine check light come on when it all of a sudden cut, what sort of fcd did you buy? how many wires are there on it?
also if your compression is only 125 you need a rebuild, the minimum in the manual is 128...
the bov you bought does it vent to atmosphere?
i wouldn't think your timing has altered.... check this link to verify your cps timing.. www.supra.co.nz/timing.htm
do a diagnostic.... http://www.toyota-supra.info/forums/index....ct=ST&f=2&t=333
let us know how you get on
Pics of my build.
Do a diagnostic first!
