Thread: 7MGTE vs. 7MGE
Old 02-16-2005, 08:18 PM   #1
CSUF BOY
Guest
Posts: n/a
i'm pretty sure the question has been asked but i can't find the answers anywhere. what are the differences between the turbo and non-turbo supra models? are the engines identical minus the turbos? is the tranny the same? same gear ratios? i'm guessing the ecu is obviously diff and i would think that compression on the motor is probably diff.
how hard is it to swap a 7MGTE into a non-turbo supra? is if direct bolt in? wiring harness plugs in? and plug in new ecu?
what about suspension and body wise, were there any differences beside the turbo emblem?
