I know the numbers like this because I weighed them myself.
Here is how they are from memory from my 7M-GTE.
I never had a 7M-GE, so I can only tell you about the turbo version.
100 lbs R154 manual tranny dry with no oil (actually, I got that from sammydafish's site)
135 lbs 7M-GTE bare block with main caps on.
52 lbs for the 6M crank
57 lbs for the 7M crank
60 lbs for the complete head with out valve covers or cam gears
I think you will be looking at, with your setup, about 525 lbs.
That is a guesstamite, but that is all I can do, only make an educated guess.
I am keeping track of weights and plan on disclosing all that info soon.
