newbie
i just found dis forum 2day and had to join, well my supra will be in my hands by june, everything finalized, still doing some mods on it, pushing about 700hp and doing low 10 secs in the quarter. here are some of the specs i am so smiling right now:
- 1994 Toyota Supra
- Crower Billet Steel Rods
- JE Forge Aluminium Pistons
- Hot Tanked, Deburred and Magnafluxed Block
- Magnafluxed Crankshaft
- Block Bored to 88mm, Decked and O-Ringed
- ARP Hardware
- UPRD Girdles for Mains
- Pistons Crown and Skirts coated by Swain Tech
- Full Port and Polish with Multi-Angle Valve Job
- Decked Head
- 8:1 Compression
- Valve Facings and Top of Combustion Chambers coated by Swain Tech
- 264/272 Jap Spec HKS Camshafts
- AEM Adjustable Cam Gears
- ARP Headstuds
- Racing Oil Pump
- Flow Benched tested Manifold
- 85mm Throttle Body
- Fully Polished Engine Bay
- Chromed SP-76mm Turbo
- GTS Trim
- HKS GT Header
- HKS GT Racing Wastegate
- Turbine Housing and Header ceramic coated by Jet Hot
- Polished HKS GT Front Mount Intercooler
- Polished Custom 85mm Intercooler Piping
- HKS SSQ BOV
- SP Custom 3 1/2" Downpipe
- Dual In-Tank Walbro Fuel Pumps
- Independant SS Braided Lines
- Opposite ends rail feeding
- 1000cc Injectors
- Injectors Balanced and Blueprinted by RC Engineering
- Powerhouse Racing Fuel Rail
- Paxton Adjustable Fuel Regulator
- NOS Direct Port Kit 200Shot
- NX Bottle Heaters
- NX Bottle Blankets
- AEM EMS Controlled Single Stage
- Custom Racing NX Intercooler Fogger system
- AEM EMS Controller Fogger Shot
- NX Bottle Blanket
- Apex'I Peak/Hold Boost Gauge(2.5 bar)
- Apex'I Peak/Hold EGT Gauge
- Apex'I Turbo Timer
- HKS-EZ Boost Controller
- AEM EMS Tuned by worlds best EMS Tuner, Justin Nenni
- HKS Twin-Power Ignition Amplifier
- FJO Wideband Kit w/ AFR Display
- Earl's SS Lines
- Hurst Line Lock Kit
- Custom KYB 4-Way Adjustable Shocks
- GReddy Front Strut Tower Brace
- Cusco Rear Strut Tower Brace
- TRD Front and Rear Sway Bars
do u guys know where i can get a roll cage from, for it.
